View Single Post
  #19
Old September 6th 2006, 04:27
Humble's Avatar
Humble Humble is offline
I started fabbing up the nose cone mount from some 2"x1/8" flat stock and ended up drilling the holes a little too far apart. A little bit of grinding and its a clean fit. Then welded it together and I'll grind it down tomorrow. Here's what I'm thinking for a main transmission mount similar to a bus to hang the 091 from. Then I'll fab up mounts on the bottom from the motor to the tranny saddle.
