View Single Post
  #31
Old July 23rd 2013, 20:30
flat flat is offline
Originally Posted by SuperRSi View Post
Hey Lanner! Is it four weeks yet?
Mild progress. Working out the design features:
-fixed positive caster gain. Question is how much? I'd appreciate feedback. Walter? Steve C?
-I'll design for max camber adjustment. 2 bolt struts will have more since the hole in body is bigger. On early cars its up to your discretion to clearance body.
-looks that there will be very little change in ride height..+- 4mm
-can be removed/replaced without affecting setting
-easily adjusted from under hood
-will be non cushion mounted for now; good for the racers, a little harsher for daily drivers
www.vdubengineering.com
