rear brace threaded aluminum ends
Does anyone know what the threaded ends on the kafer cup brace are called? I have been researching and found no information, the closest thing I could find was the heim joint but that is not what I want to use. If I can find these ends I will complete my front strut brace and start building a rear brace.
Are these ends custom machined or are they avaliable from a source? I don't want to spend $600 CDN dollars on a rear brace when I can make one for alot less than than.(depending on how much the threaded ends are)
Thank You
