View Single Post
  #25
Old March 13th 2010, 12:45
dub_crazee's Avatar
well ive been working on the chassis this week to get it finished. ive shamelessly copied a couple of ideas off of another project build on here but as it ws one of the neatest installs ive seen it seemed silly not to!
The rear mounts worked a treat but needed 8mm spacers between the framehorn and cradle
and this is the front mount welded together
which was then trimmed and neatened up
the shift rod was shortened 20mm
and the underside of the chassis was closed up similarly to the other project build.
Framehorns were clearenced for the Larger CV joints
and kafer bar set up mocked up and the tabs welded in
i only had 1 short and 1 long bar to do this as the rest is still being made
i also ran the fuel lines
its off to the blasters and powdercoaters next week, then the obttom is being gravitex'd and painted black (over the powdercoat) then i can start to think about building it up!
Classic Car Revivals
www.classiccarrevivals.com
