View Single Post
  #85
Old May 13th 2011, 15:53
Great work again!! A true metal master! Nice brake proportioning valve. I will be using a similar one also.
Thanx, I have a bias balancebar that can be adjusted with this cable and I have a 7 stage reduce valve on the back brakes. The correct setting must be there somewhere
