I just swapped my subaru EA81 for a wasser
Used aftermarket 200mm Type 4 flywheel from ebay. moddifed stock exhaust to clear trans
the 1.9l cooling is a bit easier in a bug because of the thermostat housing. also the wiring is dead simple if you use all the stock fuel injection.
