View Single Post
Old November 17th 2008, 03:14
Hi Wally
Would they fit on the front of a 944 setup?
No, the bolt spacing of the rear of a 944 (all models) is 94mm IIRC and front 944 is 76mm bolt spacing. Also to remember they are for a 24mm disk; not many front disks are 24mm but you could make s/th work I' am sure.
So your running 48 mm front callipers are you running the stock M/C?
Yes, with the stock front solid disk. Very hard/high pedal. Really pulls it to the ground on all 4 corners simultaneously. Its an amazing sensation as the car doesn't dive anymore under braking because of that. I do encounter the rear to lock up first in some extreme situaties, which isn't good, so I want to install something porsche/brembo in the front as well one of these days. A bigger disk will probably avoid fade and bite a bit harder/longer so balance will be a tad less agressive. Though I really like how it brakes now, even with the knowledge it could/will lock up in the rear in the end.. I know I' am weird/suicidal
