Hi om one engine I adapted the water temp sensor to the same place as the thermostat but it melted so I just commected the two wires to each other and it worked fine. Since this is basically a variable resistor which tels the computer to enrich when the engine is cold I am sure you could get a variable resistor and dash mount it for a kind of manual choke (South Africa doesnt need a choke much) You can also adjust the rev limit by replacing one part in the brain searc a bit on the net) My memory loses me on this one
I have found it to work well and have also thought of installing the temp sensor in a location where it would be in contact with oil as the sensing part is copper it wont melt
Armand
IMPI
