ok tell me if im understanding this right please.
I was playing with the wheel calculator.
My currents are 4.5 with 0 offset
the 15x7's are 38mm offset
It says inner clearance is 70mm less (from inside wheel to strut housing or in my case, spindles?)
Then outter position it it says retract 6mm (from possiton of outer side of wheel)
So will the 15x7's be closer inside the fenders an be ok?
Then the 15x8's which are 15mm offset
Inner clearance is 59mm less from inside to the strut?
Outter position will extend 29mm (from possiton of outer side of wheel)
So whats that in inches, Im not real good in measurements
found a site:
15x7's
38mm=1.49606in.
70mm=2.75590in.
6mm=0.236220in.
15x8
15mm=0.590551in.
59mm=2.32283in.
29mm=1.14173in.
so if i did this right, im understanding there fine but will stick out a tiny bit which is ok
