View Single Post
  #1424
Old August 13th 2016, 16:06
Yes, its an Orratech system. It wasn;t designed for type 1 exhaust port heads though, but thats easy.
The disk hat is original Porsche, but off-set is a few mm short.., so it doesn't work/fit at the moment and I need to adress that issue as well before I can drive again.
The off-set problem is not as simple as it sounds to be though.
On the positive side, I did find the other caliper!
