long time ago
but i thought showing how it is looking now
intercooler intake both windows are moved 15cm about 6 inch inside in the rear
outlet is under the little wing on the back
youtube:
http://youtu.be/-2wilTC5Cs0
http://youtu.be/GrFrrbbncL0
http://youtu.be/fae2gHi20fE
http://youtu.be/L1PKfK_BaWE
car spec:
VW 1303 beetle 1972
engine
2002 subaru wrx sti (bugeye model) ej207 sti engine VF35 turbo
engine is stock
ecu: 2002 sti jdm ecu (i used jdm ecu because no need of immoblizer and keys instead of euro models)
ecu is ecutek remapped to 98 oct fuel and runs around 1,5 bar boost
should have at least 325hp+. it is not been on the dyno yet
rev.limit 7800rpm
i can get 120klm (75mph) in second gear
exhaust:
custom made 3" stainless steel with 2 magnaflow 4" mufflers
i'm driving with DB-killers it is now 2 times 2,25"
but it has no influence on the power or spool up of the turbo
but driving without db killers makes it like a rally car sound
there is a youtube link above
gearbox:
porsche 911(964) G50.03 5 speed gearbox incl shifter
that is modified to custom shifting linkage
clutch adapter kit
KEP: adapter kit
sachs stock 911 pressure plate
and high performance 6 puck kep clutch plate
spec can hold up to +/- 850nm
suspension
front: fk-coil overs
944 hubs and brake discs
porsche boxster brembo calipers
custom made steering arms/rods
custom made stabilizer bars(cupstrebe
rear: 944 suspension arms and brake discs
custom made stabilizer bars(cupstrebe)
red9design uniball system
spax coil overs
wheels/rims: steel rims 16inch rear245/45/16 front215/35/16
pre 65 chrome covers
fenders front fully steel: front widened 2,5cm 1 inch
rear widened 6,5cm 2,5inch
fully roll cage incl doorbars
2 gt3 racing seats
4 point belts
omp steering wheel
2002 sti instrument cluster
boost, oil pressure and oil temp gauges.
and much more
i have to do some little things on the interior
and polish the paint
and i need to make a front splitter
because when doing around 200klm (125mph)
it is getting to search on the road a i need to do little
steering corrections just like in old porsche's
i going to make a splitter in the front to improve this
when it is doing better and i can test it on the autobahn next year
(i'm from holland and live 15klm from the autobahn ;D )
hope you like it
