View Single Post
Old April 20th 2010, 06:54
Blizzard's Avatar
Blizzard Blizzard is offline
To fit the yellow Koni's (which were made for an IRS beetle) on the 944 turbo arms I made a bushing from an unused urethane bussing for a 19 mm. front anti rollbar. The 12 mm. hole is to small as you all know for the 14 mm. Bold for the 944 turbo arms. So I made a 2,5 mm thick steel insert outside 19 mm. inside 14 mm.
