Originally Posted by DORIGTT
The 901 can be primarily found in the 914 though some early 911's had them as well.
Only "some"? What other gearbox do you think early 911s had?
In fact, all 71 and earlier 911s and 912s came with a 901 gearbox. If you are going to install a 901 into a VW, the 914 is not a good start. The side shift 914 gearboxes require a bunch of parts from a 911 gearbox to make it tail shift, so why not start with a 911 version to begin with?
LSDs for 901 gearboxes are quite rare and very expensive. If your project requires a LSD, a stock Thing ZF is the one to get. If that is the route you choose, and you need 5 gears, the Berg 5 conversion of an existing 73 or 74 Thing gearbox will produce a great gearbox.
