from the pics you provided in the other thread on HID's, the headlights you found will indeed fit your headlight assembly and may only require a trim here or there on the actual metal housing. Its hard to explain but once you attempt to install them you will know what I mean. It will only require a snip here and a snip there. No real headache. I say about 10 minutes with some metal cutters!
