View Single Post
  #18
Old September 6th 2006, 04:19
Humble's Avatar
Humble Humble is offline
Still no definitive answer on my previous question, just too many variables. I was told that the force needed to release the clutch varies due to clutch plate thickness, flywheel wear, flywheel surface depth and so on, and that the force needed is not linear with wear or different clutch plates. So I went ahead and ordered a 1" dia titon master cylinder, to be continued...
Work has been progressing, little bits here and there. I had taken more pictures but our net access hass been down for the past week (we're on a long haul wireless setup) so I couldn't update or upload till now.
I've been waiting for some time for a bus-into-bug transmission adapter kit, about a month now, and it's kinda holding up everything else. I realized that A) I was probably gonna hack it up to make it work how I wanted and B) judging from the kit I could make a better one for less. So off the to metal supply I went. With stock on hand I started playing with how the transmission would sit in the car, how high and how far forward I could put it. The goal here is to raise the transmission and tilt it forward a few degrees so that maybe I don't have to modify the oilpan or exhaust or modify them very little (optomistic I know). I had to cut into the body to clear the nosecone and to make room for the new front mount. I also replaced the type 1 cv's with new bus cv's on my old axles and test fitted them to see if they will still work. They are 21.5" long from a late model vanagon and were perfect for the porsche swap and type 1 tranny. They felt okay-ish but i'll need better measurements (and pictures) once everything is set in stone.
