Originally Posted by effvee
Hi, from what I have noted, the distributor drive gear, must remain. When I was buildings a friend type one, until I installed the distributor drive gear , I had excessive crankshaft end play. It took the dive gear installed in order for the end play to be set. Let me be clear, both the brass gear and distributor drive gear are needed.
i disagree, i cant find a post of a guy that forgot to remove the distributor shaft and found the brass gear all over the oil sump ....
however i did find this
http://www.electromotive-inc.com/pro...kit-220-72401/
scroll down the page
only the brass gear is needed .
