Originally Posted by djmatio
Hello,
Doing a search tells me that people are using either the standard super master cyclinder or the 944 n/a m/c after doing a disc brake upgrade.
I have a '72 1302 with 1986 944 turbo calipers and discs and would like to know which m/c to use. I do not have the 944 m/c. Which should i use? If the 944 is suggested, is it off the n/a or turbo car?
thanks
Like search showed you already, different people report good results with all of the mentioned M/C's.
I guess YOU will have to decide for yourself who gets closest to your set-up, who to believe and/or what to mount first time. Its all custom what you do anyways, so there is no generic answer for your q's imho.
I personally have the best results with a stepped 944 M/C with reverse mounted (front x rear) brake lines... A brake balance device would fine-tune it even more.
