Originally Posted by Humble
vw shift rod, planning to use the mendeola coupler with it too. as far as I've read you can use a stock shifter after removing the reverse lock out plate under it. I don't know how the reverse lock out works on the bug-tech, so I wasn't sure of compatibility.
The Mendeola and Subaru Trans shift couplers are just a band aid job.
If you look how it mounts with that plate, when you rotate the shift rod through the left / right plain the shift rod rotates over the subaru shift rod and is hardly presise.
I am supporting the end of the rod, then running two small universals with a diagonal shaft to bring them together.
In a suby trans install, the shift rod on the trans is about 2 inches off centre.
http://www.subarugears.com/image622%20-%20Copy.jpg
