Soon i get my transaxle, berg 5-speed 091, it should be finished at week 45. I'll get berg custom mounts, since i will center the transaxle, otherwise it would sit 10mm off the center.
I might be in trouble with Mendeola A-arm suspension here in Finland, because it has
welded spindles and i might need a document that tells its meant for beetle and most important, its factory made. Billet or Forged spindles would be nice.
No help from Kevin unfortunately anytime soon, but i might have source for special one piece spindles, or just use stock spindles and have made my own upper arms to correct caster and camber..
Allthough i do have also a sketch about the document..it is pretty simple and i could try it first.
Ok, these are things that i should worry when the car is running
Soon will have new Megasquirt MS3 based ECU, it has splash proof automotive aluminum box and 56pin automotive connector, unlike typical megasquirt MS3.
Also the relays are built in to the box and it has most if not all the MS3X features.
http://www.autotune.fi/tuote/370/atd...n-ohjainkortti
http://www.autotune.fi/tuote/69/ms-3-prosessori-moduli
Also getting two wasted spark VAG coils for twin plug heads
http://www.autotune.fi/tuote/623/syt...asteella-4-syl
