As I had mentioned earlier, I am leaning on using the Wilwood product line, instead of the 944 MC.
They have a 1-1/16" Tandem Master Cylinder Part # 260-4893
Dimensions and specifications for this master cylinder are as follows:
Piston Diameter 1-1/16 inch, which is equal to 26.98 or 27mm
Fluid Displacement 1.20 Cubic Inches
Stroke Movement 1.35 inch
Bias Split 69% Front, 31% Rear
Given these dimensions, can anyone “guesstimate” if it would be in the ballpark. I would imagine using a proportioning valve for the front. But I am still learning..
Based on earlier readings I would think that the stroke and amount of fluid would be enough to move the 944 N/A single calipers in the front and back.
Thoughts, or comments appreciated?
But based on the front to rear ratio, it would seem like to high 2.2:1.
also a
