View Single Post
  #17
Old August 3rd 2004, 04:02
From all previous posts, the consencus seems to be that the single pots need more fluid than the 4 pots even though they have a smaller area, the longer stroke they require must be the reason. The sliding caliper seems to be pushed slightly at an angle by the 'spring' that holds one half onto the other fixed half's sliding face. If you see what I mean!
Maybe your N/A brakes were borderline and as they wore together that reduced further the fluid required as everything beds in together resulting in a pedal that is OK.
Rich
