Still in progress-seats are finally done-took over 6 months to get done.The rest of the car is finished-carpets/door trims/stereo system etc.Have started to fit the fuel injection.Using 2 x 48mm throttle bodies locally made and all the controls are Delco from a locally made 4 cyl car.Making new throttle rods and fuel rails.Done a fair bit to my drag car as well-finished welding the pan-ended up making it 100mm longer and 100mm lower.Cut out the rear floor pans and made a flat floor right thru.The roll cage is in and finished and I have cut the body ready to remove the rust and make the whole rear panel so it screws on.Will make the back ute panels out of thin aluminium and it will also just clip on.I have cut 70mm from the front beam and fitted 1 adjuster,but will probably weld in another to try and get it lower.Have got dropped spindles on it but can't get it down level with the back.
