Originally Posted by Typ Vier
PORSCHE says no, it is not possible nor allowed to machine them, once worn or damaged they need to be replaced no if or but.
If you use a diamond grinding tool similar to the flywheel grinding as mentioned earlier it may work but chances are that they will shatter.
Originally Posted by 1500Bug
I know quite a lot about the ceramic brakes, ...
The pictures shown of those discs. They are shot. UNusable and NOT machineable.
Ian
Well, people have told me before some things could not be done (using 964 cylinders on a type 4 for instance), but I am a stubborn sob....
Today I wanted to show you it IS possible to machine them and I HAVE done it!
They look fiber-ish, but are very smooth, I assure you
Its just difficult to capture with a flash light.
Still not proof they will work on the car, but one thing at the time
Walter
