View Single Post
Old February 24th 2010, 14:36
Dimensions for what bits? It's a 3/4" ID spherical bearing with matching housing (from ebay) that was welded in to the 6mm thick plate. The kerscher struts have a 14mm thread, so the bearing needed sleeving down with some 3/4" thick-walled tube drilled through and an angular spacer welded on to the bottom to give a decent area for the top spring hat to sit on...
100mm sounds right for speedbumps (not questioning you there!), good to know about the kerb height though as I do normally hold my breath when going close!
