ahhh the good old 915 box in irs bug pan, allmost like 901 till it comes to cv joints. well this is what i did, bearing in mind i use 944 trailing arms.g box end remove the cv drive flange (if its an early type with 930 size cv,s) and replace it with one from a 914 box, goes straight in then you can use 914 cv because this has the same inner size fitting as bug driveshafts(which i use) then brake end use the 944or type2 size cv because this all so has the same inner size as bug drive shafts. regards Lee
www.laperformance.co.uk
