Nate,
I will share the short version of my experience in hopes that you don't have to repeat my costly mistakes... First, buying a "Rebuilt" trans from anyone other than a Porsche shop that knows what they are doing (carquip for instance) is just a bad idea. My "Fully rebuilt Transmission" ended up being a spray paint job with guts that looked like
this when I opened it ... Go ahead and click through those images to get a very clear picture of what I mean. The trans I bought was not at all rebuilt, in addition to the oil in this trans having NEVER been changed, there was a huge crack in the bell by the starter requiring repair as
seen here that the seller had "JB Welded to hide before spray painting the trans silver. 1st gear was cracked in half, and reverse was missing teeth... both needed to be replaced.
Now understand that what I purchased was an Ebay part from a private "Porsche collector" that assured me that my purchase was a great deal ($1300.00 'Fully Rebuilt'). It is an earlier 1969 Aluminum Case 5sp 911-901 Transmission. I fought for 6 months with the seller once I got the trans. and saw the huge crack in the case... I had been lied to and robbed and only got a couple hundred back... However I just kept the trans to use as a rebuild core. I then found a local Porsche Specialist that I had totally gut and rebuilt the entire trans from 1st - 5th with custom race built bits setting it up to handle just about 300HP if I NEVER Drag launch it, which isn't something I ever intend to do. The only thing I left out was a new aluminum intermediate plate ($450), I will save that upgrade till next year. Spend the money and do it right the first time. I wasted so much money and so much time thinking that I was going to get a good deal... it cost me almost twice as much all said and done, as it would have to buy a good one the right way, up front.
In that I am working with an Early 69' Alu trans I had to come up with (and have just finished this weekend) a custom solution for mounting the trans. Allowing me to use a traditional bug trans cradle and stock rubber trans mounts. And unlike the later 70'-on. Magnesium transmission I had to figure out how to connect the bell to the trans cradle without being able to just drill through the case as you see in most "901 conversion write-ups
'. You can see my
solution here. Click through those shots to get an idea...
Also, I am running all 944T Trailing Arms, Brakes and bits... so I had to get new
output flanges to support the 944t axles trans to hub... I have more insight about this if you need it.
The root of my point is this... A. Plan on rebuilding whatever you buy. It's just the right way to do the job. Or, B. buy something that is already built / re-built from a reputable seller (carquip is great to do business with).
Spend the money once...
Parts list:
Transmission (possibly custom flange solution depending on axle choice)
Throwout Arm (probably tweaked to work)
Custom Mounting solution front and rear (cutting a hole in the bottom of your pan)
901 shifter assembly (
best solution IMHO)
901 Shift Linkage (
plan on rebuilding it, you need a hydraulic press to do so)
901 Shift Shaft (
the proper cup, bushing and flange are important to smooth shifting)
Kennedy Adapter Kit (
Mines 901-subaru2.5T)
that should help you understand a bit more...
let me know if you have any questions I am more than happy to share whatever I have learned in this process.
Also, I have to say thank you to everyone that has helped me figure this stuff out and get this far along in my own build. Great community, Great People!
cheers!
