Brief intro first.
I have several carbon fibre parts on my car (Running boards, rear remmelle style wing, headlamp rings, dashboard sections, airdam), some of these parts that are exposed to the weather didnt take kindly to our British climate and had gone very gray and washed out, with chalk rings where the rain had dried and they really looked terrible... I was almost at the point of binning all carbon as a bad job!
So I thought to myself, if its just gonna be chucked away, at least try and bring it back to life... Worst case scenario it still goes in the bin!
Started with 400 grit wet and dry paper, wet and with a dash of washing up liquid in the bucket. Then 1000 grit then 1500 grit (the higher the number, the finer the paper). Left the parts in the sun for a few hours to dry off, then sprayed the visible side with 2 pack Lacquer.
Results speak for themselves:
Unfortunatly I dont have a before picture!
I am going to further work the results by using 2000 grit on the lacquer to knock the high spots off, then a second coat of lacquer... This time the parts will be hung up so we can do all the way around (in theory totally sealing them). Then a further rubbing with 2000 grit then polishing with an electric mop.... I want a REALLY tasty finish!
Cheers,
Sam C
