So, If I understand correctly, you are redrilling stock 4-130 drums/disks to Porsche pattern? There isn't enough meat in the new holes to tap for the 14mm wheel bolts. I spotface the back and then press in the studs. It's the only way I do 'redrills', helps me sleep at night.
