does anyone make adapters for 4-130 to 5-130, to fit cookie cutters?
Nevermind I found some from Wolfsgang site for 69.99 a pair, also klearning something new from there site.
A lot of people think that wheel adapters are weak and you will have problems. Well, that's only partially true. The truth is, if you go from a small pattern drum to a large pattern wheel, or a small pattern drum to a small pattern wheel, then the adapter is flat and is as strong as the drum or stronger. But if you go from a large pattern drum to a small pattern wheel, the adapters are weaker, because they have to flower out and we don't recommend those.
