View Single Post
  #16
Old May 3rd 2006, 21:05
tommi_nylund tommi_nylund is offline
Dear Chris.
Your callipers look 928GTS / M030 951 rear-callipers in my eyes.....
You can use any Porsche rear disk below 300-305mm and 24mm thick with them....I think..
But I´m not sure which is best choice to get handbrakes work right. I´ve been searching information if I can use 951 rear disk (951.352.041.01) with n/a handbrake stuff and n/a control arms etc...?? And I think it would be possible?!?
You cannot use any front disks because they don´t have drum area to handbrake. You will need 180mm diameter inside the disk hub to get handbrake assembly fitted in.
993 352 041 02 Disks will be fine too, I think.
I tested my callipers (928 GTS) with n/a a-series 944 original rear calliper carrier, steel arm and n/a 20.5mm disk and everything seem to be ookay. Maybe it is good to use 1.5mm spacers between the brake pad and pistons though.
