Old August 26th 2013, 00:38
effvee effvee is offline
Rear trailing arm conversion
Hi everyone, question was there a Mendeola type of suspension conversion bein offered for the rear to replace all of the IRS currently bein used. It was clearly for the rear(not sure where I saw it)
Old August 26th 2013, 05:22
Yes, they offer suspension kits for front and rear. Real nice kits by the way!
Old August 26th 2013, 16:54
SuperRSi's Avatar
SuperRSi SuperRSi is offline
This is a Mendeola rear on a tube frame car
Another look
Without wheel
These arms are 2 inches longer to bring some weight forward and 2 inches wider to take the large wheels that take the higher horsepower...
Old August 27th 2013, 00:06
not these
Hi, sorry but not these, they were almost upper and lower control arms. They replaced the complete back end, served me right for not bookmarking it
Old August 27th 2013, 01:05
The only other ones I know of are for off road use. Mendeola is the only rear trailing arm kit I know if. Red 9 has a front double wish bone set up also, however I like the Mendeola much better.
Old August 27th 2013, 06:55
mendeola
Thanks, I guess it was not on the G.L.site. This setup was a complete assembly, that is bolted and welded on, I believe the torsion tube would need removing, or the set-up would weld to it; it was not just the trailing arms.
Old August 27th 2013, 15:05
red 9 have a rear double wishbone set up for buses, not sure about beetles...
