Old June 26th 2012, 22:24
effvee effvee is offline
Tail shaft gaskets
Hi, I'm in the process of removing my tail shaft, well as of today I have it off. Since I am doing in install on the cheap, I have removed the speed-o sender, trying to get the trans closer. Upon close inspection, I find that having my friend mill off the protrusion of the speed-o bump will help me capture the closer install. The intermediate plate wanted to loosen, I believe it had been leaking in the past. has anyone removed the intermediate plate and gears without removing the stub axles? I think I will need to re-gasket the area.
Old June 27th 2012, 02:36
owdlvr's Avatar
owdlvr owdlvr is offline
Page five of my build thread. http://www.germanlook.net/forums/sho...t=11341&page=5
I've pulled the tailshaft and intermediate plate without pulling the diff or stub axles. Once I had it out, I found an old seal mashed up inside which is why you'll see the diff and side plate all removed. Let me know how I can help.
'71 Type 1 - Rally Project
'75 Type 1 - Family Heirloom
Old July 1st 2012, 23:58
Hi Dave, I read your reply but I did not read if I could replace the intermediate spacer gasket with taking apart the gear stack. Did I miss it?
Old July 2nd 2012, 00:54
owdlvr's Avatar
The intermediate plate gasket can be swapped without too much disassembly. You will need to remove the nose one and reverse gear assembly. Then the small cover on the side. The intermediate plate slides out with the entire gear stack. There is a trick with the shifter to get the stack out, but I'm not sure I totally remember it. I think it was simply put it into neutral first.
Any how, slide the gears tack assembly out of the transmission case, swap the gasket, and slide it back in.
Old July 4th 2012, 22:17
Ok
Ok, I start on it as soon as my machinst mills off my speed-o housing.
Old July 12th 2012, 20:24
[QUOTE=owdlvr; There is a trick with the shifter to get the stack out, but I'm not sure I totally remember it. I think it was simply put it into neutral first.
-Dave[/QUOTE]
Hi, I'm in the process of having my tailshaft welded. However I can't remove the intermediate spacer and gears. I can feel it engaged with the side plate. Is there anyone on this sight that has pictures of how to remove the intermediate housing and gears. Dave is correct, in that I will need to put the shafter into some gear. At present I can turn the input shaft and the tail shaft spins, so it is in gear.
I need to have the tailshaft housing welded, but I think I can do it on the cheap.
I plan to go to summit racing for a trans cross member
Old July 13th 2012, 03:19
owdlvr's Avatar
Turns out I posted directions on how to remove the intermediate plate assembly on another forum. I'll find the link tomorrow when I have my laptop and post the info here.
Old July 13th 2012, 13:35
owdlvr's Avatar
Okay, here is my initial Pelican Parts Post. This is posted in full so that you can understand where i was at with my trans:
Originally Posted by owdlvr View Post
First time post on Pelican parts, so a bit of background. I'm actually a Type-1 (Beetle) guy, currently installing a Porsche 901 transmission into my beetle. The trans I have is from a '68 911, the code on the bottom is 901/1, and there is 224715 lightly stamped in the bottom as well. I have done a search, and read as many of the 901 rebuild threads as I can find on here...plenty of questions were answered. Unfortunately, I searched too late!
In the Volkswagen world, the Porsche 901 swap is relatively well documented, and there are light tear-down threads showing nosecone replacement, flipping 914 diff, etc. Based on these threads I assumed removing the nosecone would be a relative straight forward procedure. I somewhat confirmed this when I read a tech-article on the first and reverse gear R&R in-car on a 914.
Initially, this is as far as I was able to get:
The nose cone would not slide up any further, which I now suspect was due to corrosion on the shift selector. I could feel the shift selector moving and hitting something deep in the transmission, and not wanting to damage anything hit the web for some searches. Once I removed the shift guide from the side I was able to manipulate the shift rod up high enough that I could hold it with one hand while working the nose cone off with the other.
And here is where I'm at now:
Problem #1
I've knocked the shift rod off/out of whichever detent it was sitting on inside the transmission. I have no idea what gear the transmission is in, or where the shift selector piece should sitting. (part number 11 in the diagram below). How do I make sure I put this in the right spot?
Problem #2
When removing the nosecone, I unfortunately also had the intermediate plate slide up off the transmission case. I anticipate the paper gaskets have been compromised, so I've ordered a gasket set. I've read up enough to know that I need to measure the thickness and match the new gaskets correctly. But this does mean I'm going to need to teardown the transmission more then I was anticipating. I'm a little confused on what exactly I will need to do here, since I'm not planning on rebuilding any parts.
The tear-down and rebuild threads all talk about locking the transmission into two gears, and removing (or loosening) the pinion-shaft stretch bolt using a deep 30mm socket. What I can't tell, is whether or not this is a required step to remove the gear stack and intermediate plate, or whether this is done because it's easier to loosen the bolt with the gear stack in the transmission. If one is simply looking to replace the paper gaskets between intermediate plate and case, what are steps required to remove the gear stack?
When replacing the gear-stack and intermediate plate into the transmission case, do I need to have a particular gear selected? I seem to think you have to have it in a particular gear for the set to "click in"…but I might be thinking Audi Transmissions.
From another thread:
From this I gather neutral, but I'm confused about the shift rod…does it come out/in with the gear stack, or does it stay in the transmission case. Based on the fact that all the shift forks come out with the intermediate plate/gear cluster I would have thought the shift rod does too.
Some notes
- I am fully aware that this is the ideal time to rebuild the transmission. At the moment, its not in the budget. I have a beetle completely disassembled to the shell and we all know these go waaaay past the planned budget!
- For now I will re-seal this transmission and install it into the pan, so I can pickup my painted body. A full rebuild is down the road, once the finances recover.
Bottom Line
Some basic disassembly and reassembly directions so that I can replace the gaskets would be great. I already have the nose cone, side cover/shift support, reverse switch and rod removed. I have no idea what gear is selected and don't want to make any mistakes moving forward!
Are the paper gaskets installed dry, or with a light coating of aviation gasket sealant?
Thanks in Advance!
I posted this the next day:
...no time to wait.
Full details once I get this all figured out, but should someone be reading this thread in the future...it's quite simple. In order to pull the gear stack out it doesn't matter what gear the transmission is in, and that 30mm stretch bolt doesn't need to be undone. I did have issues with the shift selector rod causing the assembly to bind on the way out, but I just slid the unit out half way, manipulated the shift rod and then popped the whole thing out.
Found some fun surprises...will post photos later.
And then finally this:
Thank you for the offer Andy, but I managed to get it apart, resealed and back together. There were certainly a few tricks though.
For starters, I suspect there is an ideal gear to have selected when one goes to dismantle the transmission. Mine was in an unknown gear with the main shift rod dislodged. Once I pulled the gear cluster out halfway, I was able to move the shift rod around enough to pop the whole unit out of the transmission.
Reassembly is fairly straight forward. I followed another thread which said to put the transmission in neutral. It was a relatively easy job getting the gear stack in, and I was pretty sure I checked the main shift rod before moving forward. What I should have done, however, was also check each of the other shift rods to ensure they were still in neutral. Either while sliding the gear stack in, or while putting the nose cone on, I managed to select reverse gear on the transmission. The main shift rod was not in the correct spot though so once it was all buttoned up I had reverse, or a locked up transmission when selecting 'any gear'. I realized I was getting two gears at once, and popped off the side cover/support. From there I could see reverse was selected but the main shift rod wasn't in the right spot. Took a bit of finesse, but I managed to get it shifted back into neutral and sorted without cracking open the transmission again.
My gear stack checked out about as well as I expected. The first gear syncro teeth are in poor shape, which I expected from reading so many threads about the 901. Fifth gear is worn as well, but the others look relatively good. The pinion gear looked quite good so I wasn't going to bother pulling the diff. Instead I figured I'd do a quick check through the input shaft hole. As I was rotating the diff around one of these two pieces came into view...(battery for scale)
That would be the remains of an input shaft seal. Apparently at some point in this transmission's life someone drove an old seal into the transmission instead of removing it properly. It also explains the metal fragments I found on the drain plug!
It's back together, for now. I can use it to modify my pan to fit and then I'll decide whether or not I want to do a full rebuild on it. I will probably run it as-is for a bit, so I can see how I like the gear ratios with my engine. If I'm going to do a rebuild I might as well make sure it's got the gearset I want in it.
The original post can be found here: http://forums.pelicanparts.com/porsche-911-technical-forum/640066-901-teardown-help-needed.html
I hope that helps!
Old July 14th 2012, 23:58
I am no clear
Hi, again thank you very much for sharing your insight. But in my case, I have the nose cone off. I tried to remove the shift guide from the side cover. something is differently engaged and it won't allow the assembly to disengage. The side plate sort of titer totter, but won't release the engagement; if this make sense. I also note that I can't shift the tail shaft shift rod into any gear. It must be some gear range or shifter position in order for it to disengage.
Old July 15th 2012, 15:13
owdlvr's Avatar
Ahh, yes, I had that problem. The side plate doesn't pop straight out, you pull it straight out and then on an angle. To be totally honest, I tapped mine out with a small hammer the first time.
Old July 15th 2012, 23:30
Manual
Well I think that i'm going to need to buy a manual. I don't want to force things, and I also don't want to break the side cover. Thanks again
Old July 18th 2012, 20:14
Got it Open
I think it need to be in neautral, all other gears would not release. Once in neautral, the side plate came out with no pressure on it.
I noted where someone had deburred/ground on some area in the interior at some point. Because the trans was UPS to me, I don't have to old oil to inspcet. However this trans looks very nice.
Lastly, if the side plate will not come out with ease, don't force it, its in some gear; you are going to start breaking something.
Old July 19th 2012, 01:03
owdlvr's Avatar
From what I can see, that looks very clean. Better then mine, for sure.
...just in case, my "tap it with a hammer", is literally tapping with a small body hammer. "tink, tink, tink"...not "hammering". But, if it's simply a case of neutral and it pops out, awesome! Good tip!
Old July 22nd 2012, 22:05
Case seals
Hi, I am going to get the case cleaned for a better inspection and overhaul looks. I noted that both the axle flanges had new bolts. They were quite tight, I removed them in order to have the case dipped/cleaning. I'll place an order to Pelican parts for a gasket/seal kit. Question I noted that there were two gaskets at the trans case to intermediate plate, it this the gasket shims that has been mentioned?
Next question, I recall were racers that have unsed a AN-2 or 3 braided line, tapping it to the throwout bearng for future greasing. The cut an inlongated slot in the case greasing of the serk. Anyone know of this, not trying to be cheap, I just don't like to have ot remove the entire engine assembly just to replace the Throw out bearing
Old July 24th 2012, 23:10
Cleaning parts
Hi, its going slow, having money troubles . But I can do the dirty stuff, I can do it for free . So here's the plan, I want to mock up the trans. It will be much easier if I mock up the trans case empty. I have the side plate off and the diff just come out in your hand freely.
I will have the case dipped cleaned. I will temporary install the tail shaft housing onto the case, without the intermediate gear stack. I'll have my friend make me four blocks the thickness of the intermediate plate for true measurement. I don't think the whole case will be over 40 pounds. Sounds like a plan
