Old December 2nd 2012, 13:20
old gh bug old gh bug is offline
1972 Beetle porsche 5spd IRS
For sale my 1972 Tax exempt Beetle
It Has had a body off resto with no expense spared
Floorpan is IRS rear with ball joint front beam which is new and uprated anti roll bar it has Porsche 944 Brakes front and rear also with 944 M/C all brake lines are stainless as well as the flexibles ,also all fuel lines are stainless
the floorpan has been blasted and painted and sealed all new bushes and seals, all bolts are in stainless.
It has a Porsche 901 5spd gearbox along with correct drive shafts
It is running on Porsche Boxster alloys + spare with near new Michelin pilots
The body has had new heater channels and rear cross members also new wings and bumpers ,
all bright work has ben powder coated satin black the bumpers have been colour coded with rubber strips and fronts have LED indicators whilst the rear have smoked lenses
The engine is a 1679cc twin port with twin 40 kadron carbs
It has been reconditioned with new bearings seals etc
it has a German 009 distributor and modified exhaust
Also the body is fitted with Hooky's access panels to make tuning and plug changes easier
The Interior has Porsche 914 gauges and a special Porsche style dash also with VDO temp and pressure gauges ,it has a JVC remote radio CD player
The seats and panels are Scat pro car finished in a grey velour type material ( there are a couple of small nicks in the fabric
the carpets are also new ,The steering wheel is a MOMO 3 spoke detachable.
£7000 ono may p/ex for 1303 cab or something interesting
Also have this motor
I wasnt planning on selling the motor but you never know if the offer was right
the motor has only been bench run and done about 50 miles then I put the other one in for the winter !!!
Spec what i can remember is :-
CB crank and rods
alloy case
Lightened Flywheel
Kennedy stage 2 clutch
FK8 cam
044 heads dual springs
|Pauter 1:4 rockers
Scat lifters
cut length rods cant remember make
Mahle B&ps
1"5/8 exhaust
44 IDF webers italian
Porsche fan set up
Full flow oil system with all S/S lines oil cooler
Melling pump
German 009
CSP Rocker covers
Speedshop breather
Stainless fuel lines and fpg
