Old January 1st 2013, 14:56
effvee effvee is offline
Crank Trigger
Happpy New Year Everybody!
I have been going through my pic's and its been awhile. I would like to mod my crank pulley to adapt a crank reluctor wheel to it. I only have one picture that not to clear, I plan to have my machinst make a reluctor wheel to the area where that I had him add to remove the pulley when needed. Can anyone tell me how many teeth the reluctor needed, also what lengh and heigth will the number one TDC positioner need to be?
The lip for the pulley is about .250 thick, I know the reluctor wheel can be attached to it, anyone have the spec's for the TDC and I believe there is alos a second tooth setting. Thanks
Old March 16th 2013, 08:21
Jadewombat's Avatar
Jadewombat Jadewombat is offline
It depends on where you want to mount the VR or HAL sensor on the engine case. You'll probably get more response here:
http://shoptalkforums.com/viewforum.php?f=63
'66 Bus(11-window, CLK rims, disk brakes, IRS, bags, hydr. clutch, Super-1600 w/injection)
