Old January 13th 2003, 04:51
100 mm Nikasil Carrera II p+c
For an experiment, I was contemplating to adapt a used set of the pistons and cylinders of a 3,6 ltr 911 (carrera II), which I believe are 100 mm diameter to a type 4 stud pattern. Piston pin is about 23 mm, so a bushing would be needed, but thats not the most difficult part.
Since they are nikasil parts, the condition could still be good when used, depending on the engine they came from of course and I can pick them up for about € 450,-- a set.
If it would work, I might try this for a turbo set-up, hence its important they are not expensive, since turbo's tend to be known for leaning out and/or pinging, both possibly damaging/destroying the engine. The Alu/Nikasil will of course be great in cooling the greater heat of the turbo induction.
Has anybody else tried the Carrera II p+c 's personally?
Looking forward to your reactions,
Walter
