Can the traverse be used as a jack point?
It looks like it's strong enough....
Anybody done this yet? I need that jack point back there! Even if it might mess up the new finish.... ![]() ![]() |
Strong enough I guess, you could bolt on a steel plate where the jack would touch it to preserve it
Steve,
Have you jacked your car up this way? Seen anyone who has? Scary..... |
No I haven't but I'm sure somebody has, I have solid piece metal that I use, you can see it near the Porsche mount that I use to jack the car with
An excellent way to do it - make an alternate jack point.
I have a heavy type 3, and if that traverse bent I would cry real tears.. |
I've made jacking points out of a hockey puck and an exhaust clamp:
I removed the standard jacking pionts, because they are worthless and prone to rust. So I had to have an alternative. This method might be a bit more difficult if you beetle is equiped with a rear swaybar.
Currently Active Users Viewing This Thread: 74 (0 members and 74 guests) | |
Thread Tools | |
Display Modes | |
