Old December 1st 2012, 18:54
DORIGTT's Avatar
DORIGTT DORIGTT is offline
Best way to run a speedo cable w/Porsche brakes
In looking at my spindle / brake / hub setup. I can barely fit the center cap of the wheel on which means a dust cap that will allow me to run the stock speedo cable is a pipe-dream.
Is this a case of narrow the beam then run spacers to get my track back but will allow me to put the dust caps on to get a speedo that works?
AAAAARRGGGHH!
Old December 2nd 2012, 05:37
I had to dent the end of my bearing cap in to get the speedo cable to fit. Also had to sand the tip of the cable off a bit. There should be room to do both.
Old December 2nd 2012, 16:16
I cut a ring section of the cap out and welded it back together, no problems and plenty of clearance internally to the nut to do this..
Old September 28th 2015, 21:14
KAFUR1's Avatar
KAFUR1 KAFUR1 is offline
my 1985.5 944 set up
has a hole for the cable!
