Old February 26th 2003, 04:59
Jeza Jeza is offline
Telephone Dials on a 1302
Hi all
I'm asking around. Has anyone got these on a 1302??
I'm keen to put them on mine but I can't use wheel adapters or a spacer bigger than 10mm here in NZ.
The ones I'm eyeing up are 15*6 with a back spacing of 120mm, so I'm assuming the offset is the 23.3 one.
I could go to using 944 brakes but I'd need to swap to 1303 parts for the rest of the suspension and these are rare as hens teeth in NZ so finding the parts is unlikely.
From the measurements I've done it appears as though the bottom ball joint will interfere with the inner edge of the rim, and trimming the ball joint stud won't help.
Any suggestions welcome. I've also asked on STF and SBO so if you see the post there you'll know why.
Jeremy
1302 RAt "GermanLook"
