Old June 22nd 2003, 12:26
Bad bug's Avatar
Bad bug Bad bug is offline
Valve size
What are the larges size valves that can be placed in a 96mm bore cylinder head.
Old June 22nd 2003, 14:20
Tony Z Tony Z is offline
I think 46x40 would be getting towards the limit. I personally wouldnt go above 44x38 in that bore size
1969 VW aka Suicyde
www.geocities.com/suicyde_vw
Tony__Z@hotmail.com
Old June 22nd 2003, 21:12
Bad bug's Avatar
Valve size
is their a reason for not going 46x40, does it weaken the head.
Old June 23rd 2003, 08:21
vujade's Avatar
vujade vujade is offline
I think he was saying that is wasnt wise to go above 46 x 40 if you are going to use 96mm pistons.
If you are using big bore pistons (102mm - 105mm) then I have heard of people using 50 x 40 valves in a T4 head.
WinterJam 2010
Old June 23rd 2003, 16:03
A lot of people just put in bigger valves because they flow more air. Ever heard of someone "unshrouding" a valve? This means you move the wall away from the valve to allow the side nearest the wall to flow properly. If you go too big on valve sizes, you actuall put a lot of the valve along and very close to a wall and thereby actually reduce the airflow of the head simply because 30% or so of the valve is not being used porperly or at all.
1969 VW aka Suicyde
Tony__Z@hotmail.com
