Old July 2nd 2003, 17:00
Tony Z Tony Z is offline
twin IDFs???
I need some feedback.
My current engine is a 1596cc T1. Roughly Engle 100, 050 electronic ign, 8.1:1 cr, stock polished valves, mild port and polish, 1 3/8" single quiet pack.
The last few weeks I have been trying to install and tune a single, centre mounted 36IDF carb. I have been suffering with constant vaccuum leaks.
I have two options - 1) re-install the 36DCD and be happy with what I had or 2) go for a twin 36IDF setup.
I just feel that the twin 36s will make too many revs available when I drop the foot. She still has a stock crank.
Cars is used as a street car. Not a daily driver, but also less than a weekend car. Daily transport, very little traffic.
Your views????
1969 VW aka Suicyde
www.geocities.com/suicyde_vw
Tony__Z@hotmail.com
Old July 2nd 2003, 17:39
NYBugman1972's Avatar
IMO, go duals and get a rev limiting rotor if you're worried about high revs.
Mike Serrone
///BrooklynAutoRennen
Old July 2nd 2003, 20:36
not to worry, have run out of patience with the single. Using my nice new parts for the 48s, but putting in 36s. The inlet manifolds are ported for a different set of heads... I dont care right now, the car has to run. Will take it apart once I get the cash to do it properly. At least I got the parts lying around.
1969 VW aka Suicyde
Tony__Z@hotmail.com
Old July 3rd 2003, 14:41
James in SA James in SA is offline
Smile
Hey, Tony Z, nice to see someone else in Cape Town.
Cheers
James
'66 Type 4-engined 912
Old July 3rd 2003, 16:02
James
someone else in Cape Town you say. Drop me a mail sometime to my address.. Tony__Z@hotmail.com
1969 VW aka Suicyde
Tony__Z@hotmail.com
Old July 3rd 2003, 20:07
yetibone's Avatar
yetibone yetibone is offline
Hummbug ran first with a single 32/36 Weber DGAV, then dual Dellorto 36 DHLA's then with dual 40 DHLA's using a stock crank. Number 2 main journal was pretty ugly after only 38k
miles, and all the bearings, including the rod bearings had most of the babbet wiped away.
I didn't have the guts to turn it over 5000 RPM.
The 36's were WAY too small, and always ran lean, but Hummbug's got an 1835 with a bit larger cam. Yours should run good on dual 36 IDF's being a 1600. Just don't go past 5000 revs,
and don't expect over 50K miles before a rebuild.
Yetibone
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
