Old December 27th 2003, 22:15
Alex's Avatar
Alex Alex is offline
Which axles to use with al 944 arms?
I need to know which axles I need to use with my early 944 Turbo aluminum trailing arms. I am concerned about the length of the axle.
Do I need to get 944 Turbo ones or can I just take 944 ones?
Is there a length difference?
Thanks a lot,
Old December 27th 2003, 22:29
boygenius's Avatar
I don't know if the early aluminum trailing arms and the late aluminum trailing arms have the same axle lenght but I think they do. I am using a set of 1987 944-S axles with my stock type 1 tranny and 1987 944-S late aluminum trailing arms. The axles are 21-1/4'' long. They do not bind or bottom out at any point of the suspension travel. They use the VW spline so type 1 and type 2 cv's will slide right on. They are a little thicker in the middle but you can still get the type 1 cv boot over the axle. Hope this helps.
Old December 27th 2003, 22:50
boygenius's Avatar
here is a pic.
Old December 28th 2003, 03:36
boygenius,
what is that rear wheel, and what offset?
Alex,
The early 944's used 16" axles, same as type 1.
Old December 28th 2003, 10:34
boygenius's Avatar
Originally posted by Supa Ninja
boygenius,
Porsche 18" turbo twist. 18" X 10" -ET65. Part number 993.362.140.04
No wheel spacers needed. Plenty of clearance with the tires on with late aluminum trailing arms. Hope this helps.
Old December 28th 2003, 11:55
looks good on there, thanks.
Old December 28th 2003, 12:14
Alex's Avatar
So I need Turbo or S axles that were on a car with the al arms?
Old December 28th 2003, 12:21
alex, i can't seem to find it, but several months ago we had a very detailed thread on options in this area including output flange and CV options. i still have yet to fit mine up. that will be happening in the next two months though.
Old December 28th 2003, 12:31
boygenius's Avatar
I use www.pelicanparts.com as a cross referance manual.
They are showing that these axle assemblies are the same.
Manual transmission only.
1. 1985 1/2 - 1987 (944 and 944S)
2. 1987-1988 (924s)
3. 1986 (944 turbo)
1987 and later turbo axles use a differant spline pattern than VW so you would have to use only porsche cv's. Hope this helps. If you need any more specific measurements let me know.
Old December 28th 2003, 12:40
boygenius's Avatar
I think it was WHY TYPE 181 FLANGES.
I don't know how to make a link out of it, sorry.
Old December 28th 2003, 20:53
Alex's Avatar
Doh,
I should have used the search function.
Got the info I needed.
Thanks a lot guys,
Old December 28th 2003, 21:33
let us know how it goes alex. yeti sent me some axles off of a vanagon i plan on using.
i got my arms prepped for removal today. just have axles, trailing arm mount and spring plate and they are out.
Old December 28th 2003, 22:30
Alex's Avatar
Well I guess I will call some Porsche wreckers tomorrow or after new years to find some axles. I need 540-550mm axles from a 86 Turbo (I read so in the other thread). Those vanagon ones should work too.
Old December 28th 2003, 23:31
boygenius's Avatar
Try ebay for your axles. I got both of mine for $140 including shipping, from my experiences wrecker yards usually want double what the part sells for on ebay.
Old December 31st 2003, 23:22
scottystraub's Avatar
scottystraub scottystraub is offline
944 rear susp $$$$$
i found rear susp off a 87 944, axels arms rotors calipers ect. what is this worth? thanks!!!!
