Old May 6th 2005, 07:39
SteveW SteveW is offline
Can I do this?
I am planning on running a brake servo on my daughters T1. And as it would be such a pain to fit to the bulk head I have come up with a cunning plan. But will it work?
Front brakes are standard T1 disc's with Talbot Horizon Calipers
Rear brakes are Porsche 924 Turbo disc's and calipers.
What I have in mind is running a 924 Turbo servo and master cylinder mounted remotly either in the luggage bay or behind the rear seat. I would then mount a single circuit T1 master cylinder in the normal position linked to a Clutch slave cylinder to actuate the 924 servo.
It has crossed my mind that mounting behind the rear seat would be good as it would be nearer to a vacume tack off trom the carbs and also on the brake line running to the front I could install a bias valve.
What do you guys think? Will it work, would it be safe, am I nuts, should I revert to drums all round and a 30 hp 1200
Thanks in advance Steve
TIME Never enough - COST Always too much
Old May 6th 2005, 18:49
Daggis Daggis is offline
I know those big vacuum brake assist thingys are a pain in the a**.
How about using a electrical one? From one of the g60's, or some other forced induction car, as quite alot of them has electrical servos..
Old May 7th 2005, 04:39
Any further info on the electrical servo? I have never heard of them before.
Details please.
Old May 7th 2005, 08:38
Actually, quite alot of cars with abs have electrical brake servos.
Theres a picture of one in this thread:
http://forum.vw2you.com/cgi-bin/Ultr...D=1036997#ID16
What details do you want to know? Just ask, and I'll answer to the best of my knowledge..
