Old October 25th 2003, 15:07
Stuart Stuart is offline
conversion fuel pump
I've got a 1303 super with a standard 1600 fuel injection engine. I've bought a normal aspirated engine and are in the process of fitting it in my bug. The problem is that i need to swap the original injection fuel pump for a "normal" electrical fuel pump as the injection fuel pump gives a way to high pressure! Does somebothy know how i connect the pump because the original fuel injection pump is wired over the injection computer and some relays in the back. Every help welcome!!!!
Old October 26th 2003, 10:09
Rob's Avatar
Rob Rob is offline
Stuart,
Can't you just fit a fuel pressure regulator before the carb(s) ?
Rob.
Old October 26th 2003, 15:29
The "problem" is that i want do dismantel the fuel injection parts like the ECU and double relays etc. I don't know what the effect of this is for the working of the fuel pump.
Old October 26th 2003, 16:32
Rob's Avatar
Rob Rob is offline
Aha, ik snap het...
Can't you just wire the pump so that when you turn the key
it runs ?
Even with a different fuel pump you still need to sort out the wiring.
Keep us posted how you did it, I will be facing a similar problem soon
Rob.
