Old February 25th 2004, 19:19
'74super '74super is offline
Diff. Gauges For A 74? ? ?
Have A 74 Super. Don't See How I Could Put In Any Different Gauges As There Is Just One Hole For The Speedo....any Ideas?
Old February 27th 2004, 11:08
VEEMAN VEEMAN is offline
If you do not have an radio fitted into the radio slot i.e there is a blanking off plate in there made out of plastic.Then you are in luck, you can drill three 52mm holes in this blanking off plate and fit the 52mm range of VDO guages of your choice into them.I know this plastic blanking piece is hard to find in the UK.
Alternatively autoplas make a centre consol that comes from the tunnel to underneath the stock 03's dash.I think it has a place for 2 x 52mm guages.
Another way is two either use a pod that are available to mount seperate guages in ( but it depends on how many guages you want in your car ).
One last way is to buy a plate that houses the guages in ( holes already cut ) and fix it to under the dash.You might get this plate from your local accessory shop.
Hope this helps a little
Cheers
VEEMAN
