Old June 27th 2004, 00:21
'74super '74super is offline
engine stalls....
ok heres the deal. 1776cc....dual 40mm kadrons. stock heads (i think), empi single qp exhaust...petronix ignition...bosch blue coil....it won't idle. i just finished it up after working on it all winter and it will start and run fantastic if you rev it, but let it sit and it sputters and dies. please give me all possible problems that could cause this. i'm only 16, got into vw's when i was four and built this engine with my dad. glad to be a part of it all, and thankful to have a site like this. thanks for all the help....-nick
Old June 28th 2004, 00:38
beesquad711 beesquad711 is offline
Location: California (Southern for school, northern for summer)
The easiest solution might be to adjust the idle up a few RPM. It might not be the best solution but it would take you about 15 seconds. I'm sure there has to be something more to it than that but I'm too tired to try and figure it out . I hope that at least help some.
Brandon E.
1971 Baja
1972 soon (or maybe not so soon) to be GL 1302
Old June 28th 2004, 10:23
craazy Cooter's Avatar
check timing. timing could be too retarded. Check fuel pressure. carb could be too lean. idle jets could be clogged
