Old June 2nd 2004, 13:28
T151 T151 is offline
How wide a wing? (late 944T Arms)
Okay,
So late (1990) aluminium arms on a 1303 with Turbo brakes and 8" wide 17" diameter wheels with a low offset of ET30 -
How wide will I need the rear wings to be?
Old June 2nd 2004, 21:02
here is a shot of mine with late arms, 951 brakes (doesn't really matter), 17x8.5ET48, 3" CCC fenders. car is still in the air but i can't find a pic readily of it on the ground. it sits just inside the lip though.
Old June 3rd 2004, 13:56
I'm wodering if I'd get away with a 2" oversize wing?
I want to change my wheels at a later date to the porsche cross spoke. I saw a picture of them here or shoptalk, the guy had painted them the smae colour as his car (the one with custom fibrelass sloping lights - anyone have the link?)
Old June 10th 2004, 02:30
Hello,
I run the wide turbo alu arms as well and have 8x16 993 rims with ET70 and 225/50/16 tires in the back. I needed wings that were 5cm wider, but Kerscher only makes either 3cm or 7cm wider wings.
Therefore I used the 7cm wider wings (inside and outside widened) and used a porsche spacer which was + 2,5cm.
I hope this gives you some reference.
Greetings,
Walter
Old June 10th 2004, 13:37
So with ET30 on 8" wheels, I would need a 5cm + 4cm!!
WOW!!
That alot of rear wing!!
Old July 4th 2004, 04:16
d.justice's Avatar
d.justice d.justice is offline
nice tail ligths zen! truly awsome.
i need to get back in the scene
73' 1303s el vindows, ford 39's, ford mondeo indicator lights, ats 7" all around, 205-15-50 , 225-15-50,
it spits flames through a superstreet exhaust (they are long!) :help:
