Old October 1st 2003, 02:31
bc1303s's Avatar
bc1303s bc1303s is offline
Anyone Using Honda Crx rear Springs
rear honda crx springs on front 1303 struts(topline lowering struts) will it work tryn to get 17x7 inch ADR's under stock fenders (disc brake conv yes ) just lookn for a cheaper solution MAXX STRUTS too much $$$$$ right now any help would be great THANX FOR YOUR TIME!!! Bob C :silly: :silly:
73 1303s GL
Old October 1st 2003, 04:03
petevw's Avatar
petevw petevw is offline
me.......
crx springs, spring perches,
civic rubber donut thingys
on my 1302 strut.
allowed me to go 205/45/17 with a 17x7 et42. no problems.
put the rubber donut on the spring perch of your strut. weld the crx spring perch on your upper spring plate. install honda spring inbetween and voila your done. i actually welded the honda spring perch a little offset to allow more clearance for tire/rim. i bet i could put a 215 tire on it. i have my strut on its lowest setting.
anyways, hope this helps.
any more questions? just ask.
'72 super
'65 bus
'52 split
Old October 1st 2003, 19:05
bc1303s's Avatar
THANX ALOT!!!! thats what i wanted to hear do you know if the acura springs are the same someone told me they should be the same crx civic integra THANX AGAIN Bob c
73 1303s GL
Old October 2nd 2003, 03:29
petevw's Avatar
i believe the civic and integra springs will have a harder ride. the crx is the lighter car of the 3 so i fell they should be soft enough for the front of the bug. it is tight and seems pretty good.
'72 super
'65 bus
'52 split
Old December 26th 2003, 15:29
speedracer234 speedracer234 is offline
im looking to do the civic or crx springs as well..my friend has a civic hatchback, i think its an early 90's and i was wondering if his rear springs would work? im trying to do this on a budget until i can save up for the maxx's or something unless this seems to work good, also, pete could you give me some pics of your suspension? youre the only one i know of that's done this and i want to see what it looks like, thanks
Old January 6th 2004, 23:35
721302 721302 is offline
i am also interested in using crx springs untill i can save up for the max struts and was wondering what year crx i need to find to use
Old January 7th 2004, 17:32
bc1303s's Avatar
I don't believe the year CRX the springs come off will make a difference!! and if you paste the http:// from petevw's signature it should bring you to pics of his setup hope this helps
73 1303s GL
Old January 7th 2004, 21:31
petevw's Avatar
year does not matter. they only made them for like 3 yrs.
'72 super
'65 bus
'52 split
Old July 6th 2004, 14:14
coxy-ben's Avatar
coxy-ben coxy-ben is offline
pete,
From your website :
this is a civic spring ????
what is the difference of diameter between stock and civic spring ??
can I drop "extremely" my 1302 with this spring, 205/40/17 tyre on porsche replica 7.5*17 ???
thanks
Benoît
2FAST4U
Old July 10th 2004, 15:44
coxy-ben's Avatar
Question
no answer ??
you
2FAST4U
Old July 10th 2004, 17:59
petevw's Avatar
i am running 205/40/17's on the front of my 1302. no problems. i have to get this picture stuff figured out. it has a rear crx spring on the strut. i don't know the difference between the diameters. i'll have to measure. the honda spring is much smaller.
'72 super
'65 bus
'52 split
Old July 11th 2004, 13:21
coxy-ben's Avatar
Thumbs up
thanks pete !! :agree:
2FAST4U
