Old October 26th 2002, 21:42
vujade's Avatar
vujade vujade is offline
Kerscher/CSP Vented Rotors???
Do they widen the front track any?
I am concerned because they are for a 71 1302 & as you all already know, they are already wider in the front track then the rear track.
WinterJam 2010
Old October 27th 2002, 08:03
Alex's Avatar
Alex Alex is offline
I think the Kerschers widen the track by 3mm on each side.
Not a 100% sure though.
Old October 27th 2002, 10:13
vujade's Avatar
Alex, if that the case, I dont think it would be that much of a problem.
In fact, if they were up to 10mm wider, I probably wouldnt have to run a spacer in the front
WinterJam 2010
Old October 28th 2002, 08:26
My owners manual says that the front track on a 1302 is 1387 mm with drum brakes and 1391 mm with disc brakes. I would expect that you would end up with the same track as a disc brake beetle.
Steve C
Old October 28th 2002, 09:15
vujade's Avatar
my only concern is the Kersher brakes are vented instead of solid which makes them thicker then stock...???
WinterJam 2010
Old October 28th 2002, 11:51
greenterbo's Avatar
greenterbo greenterbo is offline
I am in the process of installing my CSP front brakes. I am running 16" Porsche Boxster wheels. I am not sure the width but the do fit under the fenders. I am going to have to change to either the sport springs or the Maxxstrut from Topline. Wheels/tires rub on the springs. I am not sure if the vented rotors change the track width or if it is just the rotor surface is thicker to accommodate the vents. When I get it all mounted I will try to post some photos with measurements. It may be a week or two though.
Old October 29th 2002, 11:01
Tim Tim is offline
I have the Kerscher vented disc brake kit with CB dropped spindles and 6" Fuch wheels. The tyres just rubbed against the stock fender arches a little bit when hard braking and crossing heavy bump that I needed to do some trimming at the arches. Before the conversion, I was having the stock spindle/drums with 5mm spacers and 6" Fuch wheels. I didn't actually measure the difference but obviously the vented discs are sticking out a little bit. I guess the vented discs plus CB spindles widen the track about 10mm each side comparing with the stock drums.
Tim
Old October 30th 2002, 00:28
greenterbo's Avatar
Problem w/ Kersher vented brakes
This is for 1302s only . . . The Topline disc brake bracket will NOT work with the CSP (Kersher) vented disc brake kit. Rotor rubs against the bracket. :doh: I will post a picture tomorrow. More to come. . .
Old October 30th 2002, 10:44
greenterbo's Avatar
Problem w/ Kersher brakes
Here is one of a few photos of the Topline bracket with the Kersher (CSP) vented rotor. As you can see the rotor rubs on the bracket. :disappoin
Old October 30th 2002, 10:57
Alex's Avatar
Is the caliper bracket bolted on to the spindle?
If yes get the part that hits the rotor milled down by 1 or 2mm. The bracket seems to be thick enough. Have it follow the contur of the disk and it should work.
Old October 30th 2002, 13:35
zydeco zydeco is offline
I tried installing these last weekend too...
I have a 1302 as well and last weekend tried to do the install of the Kerscher kit that Greenterbo is using. So far the problems are the inner bearings supplied with the kit are 0.001" undersized, the rotor hits the topline bracket and the inside half of the caliper hits the inboard rotor face.
Obviously the bearings have a simple solution - a different sized set cured that problem.
Both the rotor hitting the bracket and the caliper hitting the rotor can be solved by moving the bracket further in - in other words milling the bracket on the stub axle to bracket mating face! If you mill the rotor side of the bracket you will STILL have problems with the caliper hitting the rotor.
I'm talking to William at CSP-USA and Jon at Topline about this. I've also ordered a eurospec set of used stub axles to eliminate the bracket (and hopefully any interference issues), mainly because I think it will be a cleaner installation. If this doesn't work, milling the stub axle side of the bracket will be my solution.
Not that I wish install problems on anybody Greenterbo but I'm glad I'm not the only one having this problem. Are you talking to William about this stuff as well? <edit: never mind Greenterbo, I just checked my email and got your message. Let me know what you find out. Don't give up quite yet though. Victory is within reach! >
Brian
73 Superbeetle
Old October 30th 2002, 13:55
Alex's Avatar
The Kerscher front kit comes with washers for B/J beams that you have to put between the spindle and the caliper to get the correct spacing. Do not know if that is the same for Super kits.
Old October 30th 2002, 14:23
Yes, the super kits come with the spacers as well - about 4mm according to William at CSP-USA. However, the washers are meant to go between the calipers and the caliper bracket, not between the bracket and the spindle. Regardless, we need to move the bracket further inboard, not outboard. Once this is done, the caliper spacers shouldn't be neccessary.
Alex, I'm not clear about what you mean by putting the spacers between the caliper and the spindle? Does the caliper mount directly to the spindle on a B/J suspension? I'm not very familiar with B/J bugs as I've only owned supers.
Brian
Brian
73 Superbeetle
Old October 30th 2002, 14:31
Alex's Avatar
Yup, the caliper mounts directly to the spindle on a B/J front beam setup.
Old October 31st 2002, 00:21
greenterbo's Avatar
Exclamation
Still working the problem out but if you order the steel bracket from Topline rather than the aluminum you are in good shape.
