Old March 1st 2005, 21:26
NCbug NCbug is offline
stud size and press in
hi i got 17,7 and they are 4 100mm bolt pattern and i have no clue what to do , i dont have enough money to but new drums so should i just weld into the old holes and go to a mechine shop and get some studs pressed in and that is another thing ,what size studs should i use and how much is it to get drums pressed in. thank very much
Old March 2nd 2005, 09:04
vujade's Avatar
vujade vujade is offline
no you will not need to weld in the old holes.
as long as your drums are good and they are not totally worn
down on the inside, then you should be fine with having them redrilled.
the 4 x 100 pattern will fit inside your 4 x 130 pattern.
you will need to get press in 14mm studs at least 1.5" long if
you arent running any spacers.
I have 14mm x 2" studs, but I had to use a 3/8" spacer, thats why
I needed the longer studs.
WinterJam 2010
