Old March 4th 2005, 14:07
oasis's Avatar
oasis oasis is offline
MaXX Strut Adjustment Tool
That's right. The title of this thread is the same as the title of a tech article by NO_H2O.
I came here today to lurk and learn, and what do I see? The above mentioned tech article.
Now, your humble servant, Capt. Technoklutz, is in a panic-induced cold sweat.
Y'see, your dear captain is meeting with a mechanic from the shop he's been frequenting the past 17 or so years next weekend to install some MaXX struts (and other stuff) on his '71 Super. (Okay, I will stop referring to myself in the third person.)
Do I need such a tool? Will my shop -- not my like I own it -- have a proper tool for the install, or are they likely to have what you shouldn't use?
What should I do?
(At this time, I have not been able to contact the mechanic. He has yet to see the MaXX strut in person; only the installation literature.)
Old March 4th 2005, 17:17
If you are going to be at a shop with a strut comp. tool you will be able to do it with that. When I first put mine on the shop I went to put the strut together in the middle setting. I needed to put it at the highest setting, rather than take the struts back out and go back to the shop again to change the setting, I made the tool so I could make changes to them without removing the struts. If I were you I would have the shop set them(MaxxStuts) at the highest setting. This will give you a 2 1/2 inch drop and then drive it and see how much it settles. If yours was like mine it will be just right at the top notch.
Old March 5th 2005, 17:48
oasis's Avatar
Excellent. That was what I was hoping to read. Your feelings about the first setting is the same as mine. We'll see soon enough. Thanks!
